Super Jet What's this grey ish clearish box under the driveshaft?
2002zxi
Got old, bought another ski
MO/OK
On my 97 sj under the driveshaft coupling theres a grey/clear box that has a line running back to the tray area through the wall. I've never had a ski with that what is it?
It's a water siphon. It connect to a fitting on the pump that creates a vacuum when water flows through the reduction nozzle thus sucking out any standing water in the hull. It will draw water out as long as the engine is running, so i like to keep mine.
Sent from my PG86100 using Tapatalk 2
2002zxi
MO/OK
I was going to remove it and put the blowsion dual bilge bracket on it. Is that a bad idea? It doesn't appear to work real well at this point unless its just passive and doesn't work well in general
2002zxi
MO/OK
Now I have 2 500gph rule pumps between the fuel tank and engine but that doesn't seem to be the best place for them
2002zxi
MO/OK
Thankfully the epoxy had not set up and cured completely, got the bilge mostly clean as well as the epoxy off the blue bilge pump holders.
