most every hull builder uses the cheapest materials they can buy which is one reason most hulls are junk. its only $200 more in materials to use quality carbon over glass and its between $1200 and 1500 total to build a hull.2k maybe max with nothing but the best. if you don't put more matt in the crown and other high stress areas, the hull is junk. most hull builders don't have previous experience in composit, body and fender, or just using your head, so they turn out like crap. its not that difficult to build a hull if you know what you're doing. I saw the whole process at trendsetters, know costs and everything. steve could do body and paint but his junk didn't stay together. hurricane ind aint no body and paint guys which is why the finished product was rough. I imagine superfreak was the same cause they were rough.
senor /marc with the FIXX hull, makes quality cause he did his homework on the materials that were compatible with each other and for strength.
the molds have to be cherry and waxed or a lot of work is needed after its popped out.
