MikeyB
H2O-Addict®
Michigan
Watched some p51 mustang engine testing for a little bit today
OCD Solutions
Rentz, GA
How big is that chuck?
Grizzly G0602 10" x 22" Bench Top Metal Lathe
Description
Our 10" x 22" Bench Lathe sports generous capacity, a lot of thread ranges, a wider bed and a larger chuck. Yet, it costs just a little more than our G4000. With features like a 1" spindle bore, 3/4"-12 TPI lead screw & an MT#3 tailstock you'll be able to turn some surprisingly hefty projects—and a few heads! If you are thinking of making parts for standup Jetski's, models, engines or even for repairs around the OCD home or shop, take a good look at this lathe & the specs below.
Specifications:
  • Swing over bed: 9-5/8"
  • Swing over cross slide: 6-1/8"
  • Distance between centers: 22"
  • Spindle bore: 1"
  • Spindle thread: 1-3/4" x 8 TPI
  • Spindle taper: MT #4
  • Motor: 1 HP, 110V, single-phase
  • Number of speeds: 6
  • Range of speeds: 150, 300, 560, 720, 1200, 2400 RPM
  • Leadscrew: 3/4"–12 TPI
  • Compound travel: 3-1/2"
  • Cross slide travel: 6-1/2"
  • Carriage travel: 18-1/2"
  • Maximum tool size: 1/2"
  • Tailstock barrel travel: 2-1/2"
  • Tailstock barrel taper: MT #3
Standard Equipment:
  • 5" 3-Jaw chuck with two sets of jaws
  • 6-1/2" 4-Jaw chuck with reversible jaws
  • 8" Faceplate
  • Steady rest with 1/4"–2" capacity
  • Follow rest with 1/4"–2" capacity
  • MT #3 dead center
  • 4-Way tool post
  • Chip tray and backsplash
  • Hardened & ground V-way bed
  • Oil-bath gearbox
  • Tool box with service tools
  • Number of longitudinal feeds: 9
  • Range of longitudinal feeds: 0.0023–0.013 IPR
  • Number of inch threads: 33
  • Range of inch threads: 8–72 TPI
  • Number of metric threads: 26
  • Range of metric threads: 0.25–3.5mm
  • Overall dimensions: 46" L x 22" W x 16-5/8" H
  • Approximate shipping weight: 432 lbs.
Nice! We had a small one that was about 3" square at the career center where I went to high school. It had maybe a 1" chuck, I used to sharpen my pencil on it every day before class. I think it was yellow.
OCD Solutions
Rentz, GA
I was going to buy one of those little ones but they are very limited, (pretty much useless for anything bigger than sharpening a pencil). The tolerances on this one are much better, it's much more capable and it was not much more $$. Now I just need to pay back the savings account and start looking for a CNC Milling machine... :D
Quinc
Buy a Superjet
California
80% lowers in your future? :)
