I can get stuff at discount if you're seriously interested. Or you can buy the parts used on pinkbike.com i could help you find a decent used setup
the hardware comes with the stem when new and most purchases with used they include them.
I can get candycomponets stuff for a good deal they have stem and bars
http://www.candycomponents.com/
If you went used you could get it all for under 100 including bars. As far as the machine shop im not sure what they would charge i used my own mill.
The holes to drill are 50mm x 35mm rectangle 50mm being the width and are a T6 bolt. Dont drill until you get a stem and fit it correctly. Technically you could do it with a drill as theres a little room for slop.
or i can get raceface ( whats on mine)
http://www.raceface.com/ they even have carbon fiber bars if you wanted serious bling
i didnt have my stock pole on and never did so im not sure if you could run a bar with a rise. Mine pictured is 1 1/4 inch but to avoid your pad when turning you might want one with little to no rise. im just not sure on the clearance.
