Custom/Hybrid Where to buy fuel tank grommet/bushing?
I have a WDK ROK-R with a custom tank that I am having repaired/tuned up and Joe (Austin Jetskiier) told me that the part is not something he can easily order from a catalog. I do have the dimensions:
OD of fuel line: 10MM
ID of hole in tank: 12.25MM (probably a half inch?)
Where would I locally go to buy these? Offroad toys repair shop? Auto parts store? If it helps, I'm located in Austin
Thanks for your help!
Argo, Al
Very common on mowers so if you want a specific place to find them locally, check a dealer or small engine repair shop. You should be able to google “fuel tank grommet” and easily find them.
Thank you for the responses. It looks like one or two of the links provided match the specific size so I will will order (1) online while i search for a local shop.
@JetManiac I would typically support a PWC vendor in regards to replacement parts but I think this is a little bit too small of a purchase to be too choosy about. I do keep Jetmaniac in mind though regarding other mods/etc :) and appreciate your response.
JetManiac
Stoked
orlando
No worries, it is a common part used in jet ski builds.
index.php
