Put it right next to the drive shaft. Most people use the blowsion bracket to mount the bildge. It attaches to the factory siphon bildge box and located the bildge properly. Other guys use the 750GPH bildge and strap it down where your tool kit goes. I run the blowsion dual bildge bracket. I will see if I can get a pic for ya
All the brackets for sale mount at the same spot: at the stock bilge. Just decide if you want one or two a/m bilges there. Mock up your bilge before riveting/gluing/securing the bilge to the bracket so the bilge tube is aimed the toward your hull and not toward the firewall or your motor.
