Which to build 760 or 61x cyl.
XFT LOU
1 hp./1.83lbs
St. Louis
Kennay yea I said stock ish so ya all would spend my money. The current ing could transfer over since the xft is tl now. And crammit442 has a point about shelfing some domes to transfer the ADA incase!
crammit442
makin' legs
here
Mght as well just transfer the TL too. All you'd be swapping would be the trigger plate and flywheel. Set the timing and go. Take less time than moving all of the TL stuff out of the boat and installing an OE elec box. Make the boat run better too.
the only way you would get fat girls in a barrel is with a chipper shredder, and am pretty sure that lou already has a thread started on that in another section.
That depends on the size of the barrell dosen't it,I don't care I don't go for fat girls anyways.:fing02:
