Who builds the fastes HX for racing mod class???????????????
Who builds racing Hxs for the mod class...? and how fast are they on topend?
Websites,please... I am running a blsater one 135hp, I want to compare the top speeds to c which is better to compete on...blaster goes about 58mph top end on flat flat water.....
Thanx in advance!!:biggthumpup:
my 785 r motor hx runs 63 mph @7980 rpm. it is fast compared to most blasters.
two of my freinds built mod blasters that run about the same.
on has a rius powervalve 800 motor 62.5mph
one is a carbon fiber hull power valve lamey stroker judge motor and runs around the same.
both are competitive with my hx.
58 mph will not get it done anymore.
the good thing is that that there are so many good used parts out there.
i built my ski for less than 4000,00.good luck,scott
Thanx for the info!!!! Where did you build your boat??? I know the blasters are a bit slow but this thing in the surf!!haha nuff said...
The fastest hx in South Africa are parked on trailers.... I ran this blaster to a 2nd in the national 1200cc stock class... in surf...but im envius of hxs!!!!! They are the ultimate race machines IN MY BOOK!!!!!!!!!!!!!
Can you please post your specs or pm them to me!!!! Thanx for your time!!
godocgo
sport
s. fla
just goto judgemotorsports.com tim can build you a superfast hx or blaster.
my ss motor in a mod hull did 64.5 on gps in flat water. tims old strokers in stock hulls would run mid 60's all day. i know the hx can get there probably easier as well. you just need to build a good motor and pump combo.
godocgo
sport
s. fla
we are running mod rules now, but i think there are only about 4 US riders running any sort of mod. 2 blasters 1 hx and i run a mod hull with ss motor. there maybe more by WF but i don't know. that is if we have a WF's.
So what engine mods are you allowed?? full bigbore,stroker cranks,ada cylinders and lameys... unlimited specs???? Do you have a carbonf fiber hull or sumthing different??
godocgo
sport
s. fla
i run standard stoke 85.5 with a mod hull. you can run a lamey stoker as long as it is under 800 cc's. the hull most comply to mod rules. aftermarket bottom with a stock topdeck. mod is pretty much the same as open or superstock. just allowed aftermarket cylinders, cranks and hulls.
godocgo
sport
s. fla
yes he has one left to build, but they are not carbon fiber. wammer builds light weight fiberglass hulls. wammer will build you just the hull for 6000.00. the only carbon hulls i know of were built by rick pott and they all ended up in japan except for the one i have. that is what i was told anyway.
you don't need a after market hull, joe mckenna proves that. he rides a modified stocker. goes like bat out of hell too.
just ride the piss out of what you have. the only way to beat the hx is be a strong rider that does not get tired. they have it easier sitting the entire race. so you will have to out ride them with a strong boat and body.
Thanx for the info, im going with a 85.5mm now with the usual extras....r you running magnum pumps,trim systems,trim tabs,sposons aswell???? Asking coz I want to know hot the cornering abilities are?!!!?
Check out this thread for pics of the hull extensions Joe built. They are pretty awesome when it comes to keeping the hull in the water when it gets rough.
http://www.pwctoday.com/showthread.php?p=810750#post810750
As for set ups, my stock hull uses a JD intake shoe, JD intake grate (although, I think the WORX is a better grate for hook up) and a ProTec ride plate. The JD intake shoe allows the grate to sit a little lower, and works pretty good. But, the thing you need more than anything to ride the Blaster to it's race potential is endurance. You have to work constantly to keep the B1 hooked up in the rough stuff. Kind of like riding a stand up, you have to "work it" to make it right!
Scott
godocgo said:
dude, no fair. i told you i want 2 sets of those. i will pay, i promise:biggthumpup:
Those are the ones we had on Joe's ski last year, we just trimmed them to make them legal and painted them white. Over the winter, I promiss, I am going to make a mold and make a few of them. You will get the first pair.
I am mailing out your video tomorrow.
Scott
godocgo
sport
s. fla
ok but i am holding you to it, or joe too it. but i want a couple pair maybe 3.
i know phil wants them as well.
man i miss racing already. we did not ride today because of crappy weather.
hopefully i will get out with paul on tuesday.
Extensions won't be done until the fall at the earliest, we can worry about price then.
Here is a video of the 2nd moto at this past weekends National. The white ski in front is a MOD, the blue ski in second is a stock hull that has been modded. (added "V" and lengthened the hull)
YouTube - Broadcast Yourself.
Scott
