When does that actually happen though? Driveshafts will break no matter what, happened to me with stock couplers, too
Agreed. If there is an event, like a lawn dart into the bottom, that is enough to break a coupler likely the driveshaft is going with it.. along with the motor mounts. I doubt yami factored surf re-entries into their engineering. This is where the CF stronger coupler is good, it will take more abuse from out of alignment flex from impact.
But if you stick the pump with a rock that stronger CF little rubber bumper only goes so far. I would think the design is to dampen the rotation, and kill the engine before everything else snaps. The shafts are hardened steel and wont flex before they instantaneously fail. So if the coupler and rubber dampener are stronger there is more force transferred into the mid and drive shaft.
The forces it takes to snap the shafts must be incredible.
