Super Jet who selsl yamaha base gasgets
XFT LOU
1 hp./1.83lbs
St. Louis
Hello I cant find any company that sells 1/10 inch thick performance base gasget.
This is for a yamaha 701 stroker motor.
Thanks
#ZERO
Beach Bum
Florida - U.S.A.
I have the thicker gaskets up to .060" but if you want to go larger you might need an aluminum spacer plate with a gasket on either side.
I'd check with superjet-113 or jetmaniac to see if the can order you something thicker.
