who tunes jet skis near CT ?
CT
are there any professional places that tune jet skis? im in CT and will drive somewhere to get this freakin thing tuned. i cant take it anymore and i want it to be reliable
CT
i am just lost on my tuning. i had it tuned a month ago then my fuel delivery kept getting screwy so i got a new carb kit. after that carb kit my tune change dramtically. it ran like crap so i started to richen it up which made it better and better but i ended up frying my top end. after i fixed it i went up to the next jet size and i just cant get it tuned. while following group k's instructions it seems like it wants to be leaner. but by riding it rides better and better as i richen it up. no matter what low speed jet i try it rides best at 3 turns out. the top speed seems ok i can deal with that but the low speed it pulling me in two different directions. i dont want to blow up again.
CT
i have a 61x motor bored to 733cc. single mikuni 46mm carb, riva red pipe, 180 psi, prop, lightened flywheel, intake, carbon fiber reeds, msd. current needle and seat is 2.3 with a spring that should net me 15psi pop off. my high speed jets ive had in are 150 and currently 155 which seem ok. but the low speed ive tried 120, 125, 127.5, and 130.
CT
it doesnt ride to bad with the screw at 3 turns out and whenever i turn it in it acts worse. but at 3 turns out the screw isnt even involved in the system. once it hits the top speed screw it rides good and fast. i dont have a tach tho which would help. i dont have a pop off gauge or a leak tester to see if i have any air leaks
Have you done a leakdown test? A leaky motor can cause jetting problems until the cows come home.
I rejetted my ski every weekend for a year and it was just the motor leaking air. It was a new ski but the factory dropped the ball on sealing the cases.
cmeripper26
Ripper26
Connecticut
I have the tools. it does not sound like that complicated of a problem. if you wanna arrange some time i can look at it and do a few tests on the carb and the motor to find the problem and fix it
CT
yes i definitly want to do that to make sure im not trying to tune an un tunable motor. once i find out that nothings wrong or if we fix a problem then that gives me hope again!!! where in CT are u from? im in Milford
CT
well i found a buddy of mine who has the right tools and gauges to do some tests. i did the air leak test today and it passed. tomorrow were going to do a pop off test. the only other thing i can think of is that something is wrong in the carb. after this i guess ill try and tune it again
CT
ok i will, thanks for the help guys. and not you backflop lol. when do i get to see you try more backflips and and barrol rolls just to land on your head?
