Quinc
Buy a Superjet
- California
YES, I HAVE READ THE MIKUNI MANUAL MULTIPLE TIMES. And all of the other tuning guides out there..
Ski runs perfect and has a ton of power, but I cant get it to start without a primer or idle for more then 5-10 seconds.
Single 46 on a ported and piped stock bore 61x 701. boyesen reeds, and ocean pro flame arrestor
I have the return line reduced to 1/8". Should I go smaller? If so how small?
Any other ideas?
- 170 Main
- 135 Pilot
- 2.5 Seat - 14 psi pop off. Have also tried a 2.3 Seat with 14psi pop off.
- -Coffman pipe recommends 2.3 with 14psi pop off
- Carb has been cleaned and rebuilt. New needle and new o-rings on the adjusters
- Engine holds 10psi for 15 minutes
- New tank valve
- Fuel filter is clean
- All the fuel lines on the carb are zip tied on and only 2 seasons old
Any other ideas?
