Wifeys SN Superjet custom paint
Myself
manic mechanic
Twin Lakes AR
I finished the top side this weekend. I also am working on a video.....I took time lapse footage of the whole thing.
WFO Speedracer
Alabama
I think I saw something about using plastic wrap to help create that effect. or a sponge. like Faux Painting.....
Yeah I was thing Saran wrap but wasn't sure, also it depends on the kind of paint used , what I spray which is single stage polyurethane you can't do that with, it is pretty much self-leveling , I tried to put texture into a boat dash I sprayed with it one time, it smoothed right back out, no texture.
Myself
manic mechanic
Twin Lakes AR
You can see my wife applying that texture in one of the time lapse vids. You want your dominant color on first and dry. Then you can thin out a bit of your texture color and pour a bit out in a pan. Use a loosely wadded bit of plastic wrap and dab the paint over the first color. Keep dabbing over until you get the coverage you want. In this case my wife still wanted a lot of the white showing through.
Myself
manic mechanic
Twin Lakes AR
Finished the cut-n-buff on the hood today and bolted on some hardware. Closeup pic shows all the tiny metallic flakes in the black. Blow it up big and you can see greens, blues, silver, even pink!
Myself
manic mechanic
Twin Lakes AR
2 steps forward today. I got the pole installed, got the steering installed, cleaned up all the bar switches, ran the cables and electrical down the pole, and installed the gas tank.
Myself
manic mechanic
Twin Lakes AR
I also wrapped the chin pad with yoga mat, then my wife covered it in silver marine vinyl. Finally before we quit she glued down the tray pad. Wow, starting to look like a ski again!
Myself
manic mechanic
Twin Lakes AR
Another big step today.......the engine is in. I also started working on the e-box......which was a wreck! I started with a shoddy battery cable terminal. Then moved on to the stator wiring. There was nothing wrong with it but I just hate having to flop the e-box around, scratching everything in sight, just to get it hooked up! I grabbed a couple connectors out of the boneyard and with some nice military style solder shrink connections we can just unhook it! I also had to add a connector for the start switch as somebody had cut it off??
Myself
manic mechanic
Twin Lakes AR
Thanks. My wife is doing all the turf by herself. I mounted in the electrical and sleeved some wiring this evening. I put new plug wires on the oem coil......even put the awesome little 'high voltage' doo-dads back on!
