- Victoria, BC
I am looking for carbs for my 62T/61X build and found some descent 48mm that were used on a SXR. Would these fit on my Superjet with a R&D intake manifold?
i believe so, you gonna have to ajust the shaft
dual 48s seem a bit big for a 62t61x...
The big carbs will work well on this setup. But to get the best out of them you need an aggressive ignition curve
