Needing to get the hull prep done for reinforcing but the grinder is curantly in use elsewhere, so ive ended up addressing some of the smaller jobs in the meantime.
I started off by fitting the scupper valve. It was a pretty straight forward job, the only difficult part was getting the holesaw through the bulkhead. I also wasnt aware that there is a fitting on the back with a screw in that had to be cut aswell, it was a bit of a pain but got there in the end!
Once i cleaned the hole i cut some teeth into the end of the scupper tube and used it to cut through the foam, it worked a treat!
So its in but i havnt sealed it yet as i will have to remove it to finish the internal reinforcing (once i get my grinder back)!
I also re fitted the exhaust tube, when i first set out with the build i had the intention on moving the exhaust tube up a little to clear the scalloped hull. Well in my haste to get the hull painted i forgot to do, so its now a little close to the edge for my liking, its not petruding but will look alot neater 5mm higher (matching the scupper), i'll trim the hole a little tomorow.
Im pretty happy with it now, the exhaust looks awsome polished along with the scupper.
