- HOLLAND MA.
Dont know for sure but i was informed that wiseco is out of stock for 2 months...Ill call mon to find out for sure.I need 85 mm for my lam,were else can i seek these out?
Use the Riva flat top pistons part number RY1000-61X-85 and set them up at .005" ~ .006" clearance with .022" ~ .025" ring end gap.
I'd agree with the .0055 clearance, but how did you derive the .022-.025 end gap? Wiseco recommends .004 per inch of bore which is only .013ish. I've never had any issues running them in that range.
Wiseco's recommended .004" piston clearance is too tight for highly modified engines.
The next time you bore your cylinder to .0055" piston clearance, check your new ring end gap.
