Wiseco piston clearance/ring end gap in a stroker?
WAB
salty nuts
coastal GA
Finally setting up my +4mil ADA stroker. How much clearance will the 81mm Wiseco pistons need? How much ring end gap? Same as what Wiseco says for a 701 stocker?
TIA
WAB
salty nuts
coastal GA
Ok, since it is my first stroker build, I was not sure if they generate more heat and need extra clearance.
I know Team Scream gives extra ring end gap on their motors for the large exh ports.
Set it just like wiseco recommends based on bore size. The stroke does not matter on end gap.
the way weiscos expand under heat Id give a few extra thousandths.their recommendations are a little tight,I know you guys ride in winter with coldish water,just watch your restrictors I know some others here have done this as well
