Whats your compression?
you have dual cooling right?
You using race fuel to break it in? 200psi should at least be a mix of race fuel and 92, if not then yeah don't hold it wide open very long.Not sure at the moment being that I've only run 1.5 tanks of gas through it since the rebuild. After the rebuild, my mechanic said it was just shy of 200 psi. He said once she breaks in it should be around 175-180 psi.
cant run wot ? really !! what ya got a 1200 cc freestyle motor in there. come on. nice motor bulider guess he got the jetting all figured out. lol i run my jetworks 771 wot all day long.
No race fuel, just the highest pump gas I can find, which is 93 octane.
+1At 200 psi and pump fuel, I wouldn't be running WOT, either.
