got quite a bit done recently. prime and prep was pretty easy, but i am a better sander than painter. i am sure alot of it has to do with technique, but the total boat topside isnt the easiest paint to use. takes quite a bit of pressure (and 20% reduction/thinning) to spray it. in the end i had some orange peel that sanded out pretty easily.
lighting sucks, but you get the idea
and on to the graphics. amr racing "carbon x" kit in gray. great kit with thick graphics. due to the thickness i really had to work some of the compound corners, but a little heat took care of those areas
the kit came with panels for the rear and sides but i am not going to use them. prefer to have the rear just black and white.
turf is next
