(WTB) 750/800 Dual Mikuni Manifold
Found my carb manifold cracked today on my ‘96 SXI with dual Mikuni 40i’s and was told these are different than your common keihin mani. Searching for either oem, aftermarket, or someone who can do a good repair. Located in Oak Hills, CA but shipping is fine or I often travel to havasu or around socal.
Aquaholic
World's Oldest Teenager
San Diego, CA.
Edit: carb bolt spacing on (i40's) is different than Mikuni SBN44's.
I have one here fresh water use only , correct color all the threaded holes have been chased with a tap ready to roll, $200.00 shipped
I have one Id sell cheap but not sure if its for the i40s or sbn style. IF you can give me measurements I can check for you.
Look closely at the locating pins on the manifold , if they are short they are for Kehins and go into the bottom of the carbs, Kehins don't have the carb spacers , if they are long they are for Mikunis and the extra length on the pins is for the aluminum carb spacers..
