650/X-2 WTB: aftermarket Hand Pole
Im not trying to hyjack your post but is there a mod to the stock spring like a block of some sort under the spring to make it stiffer?
SW UT
A block wouldn't make it stiffer, but you can buy an aftermarket pole spring that will bolt to the metal retainer for the front of the hood, it will relieve a LOT of weight.
Vumad
Super Hero, with a cape!
St. Pete, FL
Putting a block or spacer between the end of the spring and the pole or hull would increase the compression on the spring and thus make the pole feel lighter.
It's a silly modification. Snivilous is right. Buy the right spring.
Removing the stock platic chin pad and turfing the pole instead would remove a lot of weight from the end of the pole where it matters most.
