- norwalk connecticut
Replaced the coil, replaced the rectifier, checked the main fuse. my 09 SXR will turn over on the started motor but it still has no spark. At the end of the season last year it started blowing the main fuse. I replaced it a couple times and it ran fine until the lat ride the season when it died about 50ft from the dock. i put it away thinking it was just another blown main fuse. Now nothing!!! I have had the electrical box out of this thing three times now. I even went as far as replacing the entire box with a box from other SXR that is running fine. Still no spark!!! So I have ruled out the electrical box and its components. What next? Stator? Can you check that thing in the ski to see if it good or sod you have to remove and replace? Please help...I'm about ready to light this thing on fire!
