Freestyle x-metal pole with a spring?
Pablo
sqeez bth levrs & lean bk
georgia
Who's running an x metal pole and bracket? What are you guys doing for a spring or are you just tightening it down so it stays up?
What is the correct size and thread pitch for the two bolts vs. a single. I lost one of the nuts off one of the bolts. Xmetal if full of shizz :laugh2:if they think I'm paying $45 for two bolts.
Tuscaloosa, AL
It is an oddball size. If your going to run a spring just use a stock bolt. I think 9/16 is the closest standard size but that is not it though!!!!!!!!!!! 9/16 bolt would be a tad to wide.
(not talking about the size socket you would use, the actual bolt size)
QuickMick
API 1104 AWS CWI
Stock bolt size is .555
9/16 is .562
Two choices, ream the holes in the bracket to open them up, or find a stock bolt. Good luck
Pablo
georgia
I thought somewhere it was said this was a M14 with 2.0 pitch. Am I way wrong?
