I'm guessing cause its a plastic bushing that wears, vs fancy metal bearings.
well mine are about 20 years old oem and there not worn out idk
I have a 15 yearold stock set that isn't worn out either, but until you own the RRP setup you won't understand what I mean by zero play! Yes fancy, yes costly, but an excellent steering system.
You guys means the RRP newer system not the UMI based one, right?
