X metal
Buy a rubber plumbing cap for $2.50, a hose clamp, and put it on the front outlet end.
Problem solved.
DAG
Charlotte, NC
untill it melts.
does anyone do that? I have herd of front only with xmw boxes,, assume they just plug the T somehow...? so same should apply for rear only
Why would it melt? :confused:
People have completely the wrong idea on how hot/cold exhaust really is after the waterbox.
I've ran it that way for ten tanks now, without a problem.
I partially melted mine this past weekend... I was fiddling with my pipe water screws, and when I pulled in to shore, I found smoke coming out of my hood air intakes. It may have been that I simply forgot to tighten the hose clamp enough. Either way, I felt like a huge doofus...
I think I may solder a brass or alum cap on the front part of the T, and drill and tap that plug for a fitting to inject some water...
I won't have to worry about a plastic plug, and ill quiet it down some.
wewt
edit: maybe I was idling around to much, and it melted thanks to the jetworks valve and miminal water in the box... buh
DAG
Charlotte, NC
well their are plenty of storied that PVC T's melt "all the time" this is why i question.
hell ppls skis have sank b/c of this......remember
crammit442
makin' legs
here
Do they make a waterbox without the dual exhaut T? I'm looking for one for rear only... and all i can find is the T. Where can i get one too! Thanks!
Assuming this is for the superjet in your signature, you already own the best waterbox(OEM) you can buy(IMO). You can get an X box w/o the T, but it will still be loud and your boat will NOT be any faster and only about 2 pounds lighter. Your wallet will be MUCH lighter, but shouldn't be any louder.:smile:
Big Kahuna
Administrator
Tuscaloosa, AL
and you can run 2 lbs less fuel to have that weight savings.
