300/440/550 X2 Freestyle Trim
I wonder if a "click shift" handlebar grip control would work for the trim control also, or is there not enough cable movement with this system? In other words, like a twist grip throttle, or like the old 5 or 6 speed bikes, where there is a slight "lock" into place to hold your gear/tilt setting. Hmmm
I have been doing these mods on my ski today, and I was wondering if after I chopped the rear an inch or two should I seal it or is it ok as is?
does your guys trim mods return the nozzle back to its neutral position after you let go of the lever?? if so, how? do you have some sort of spring somewhere on the trim set up?
