- Lake Stevens, WA
Found some threads on SuperJets going to internal fill, but not X2. Got three tanks, and working on an empty hull, so thinking about foaming / glassing the gas cap.
Questions:
1. Assuming I leave the pickups in same location, how would you suggest I cap the filler neck? Some sort of aluminum plug and a piece of filler neck hose?
2. For new filler location, appears to be plenty of flat area just to the right of the pick ups, use a hole saw cut a new opening to accept the old plastic filler neck? If so, what would you recommend to seal it / attach it? Need some sort of RTV / 5200 that is vulcanized I would suspect. Could use aluminum pop rivets, or riv-nuts as well. Thoughts?
Thanks all.
Questions:
Thanks all.
