I've been searching and reading a lot about X2 options. so you all know I'm a long time owner of the B1 and performed my own mods. So mech work will not be a problem. I'll try to make this easy to follow. The X2 is bone stock so my questions and options are:
1. work with the existing 650cc but can I change out the 28mm carb and use a SBN 44? if so do I need to get the later version intake mani? if not what other options do I have?
2. Will the 44mm carb work well with stock pipe? proper jetting of course.
3. If the above mentioned works I plan on replacing the stock impeller that I've read about that needs changed for better low end response. Is this a good idea with near stock motor or do I need more pony first?
4. second option I have a stock 701 motor laying around. I know I don't need to ask that question but........
5. 701 option. more money to build. I need Rhass mount and coupler and pipe. Question is: searching for a Factory pipe that fits the X2 hull, what headpipe do I need from what hull design? Or any other AM pipes fit?
6. can I use the stock exhaust mani to bolt up to the FP headpipe?
7. I understand the B1 limited chamber will fit but $$$ so what other options do I have?
8. 701 also means E-box mounting and start and stop switch mods. I have not read much about this.
9. last min thought, maybe just install the stock 701 with stock exhaust. piping should be easy.
yes or no?
yes or no?
