- Tuscaloosa, AL
Years ago on my old XMetal Pole I got an aftermarket Steering cable, may have been a WSM or SBT, cannot remember. But it would not fit thru the hole at the top, had to drill out for clearance. Currently I am running the Adjustable XMetal pole. What cables have you guys been using. Just installed a WSM cable and it bent after 2 rolls. Steering was setup correctly but I am thinking the set nut backed off and went down, causing the cable to bottom on the nut causing the cable end to bind up and bend. I honestly do not remember if I tighten up the nut or not. I will call it install error on my part if that is what happened. But what I am curious to know is what other cables people have been using on the Adj poles. I got it straightened but we all know after they bend, it is just a matter of time.
