XMW bracket with stock pole?
hangtime
Speak up ,don't kiss azz
I'm doing it too with a stock pole but with the X metal bracket and steering ,if I can ever get my stuff from Magoo's
(it's lost in the dam mail ):banghead:
Ohio
Yea its the same. It fits nice. I'll post a pic in a couple of days unless someone beats me to it. I'm using XMW bracket with stock bolt and 2 nuts with like 3 washers I think. They say it wears out the plastic bushings every couple seasons. I'm running a -2 pole with -1 UMI plate. It works really well!
SJBrit
Extraordinary Alien
Bradenton, FL
Awesome - that's all I needed to know.
You need to use the stock bolt. The XMW bolts are too short to work with a stocker. That means you can use something similiar, but it neeeds to be longer.
i just looked at my post and think i might have messed up i ment can you use the x metal bolts when using the x metal lowerd bracket and the stock pole?
Cool...good thing to know. I had talked to him about it before, and he thought it would be too short (bolts).
Since he had them both on hand this time, I guess the verdict is it works.
Reviving an old thread!!! :
When using an XMW bracket with a stock pole and stock bolt, are there any other mods that need to be done? Grinding, cutting, etc.? And can you still use a spring (UMI)? (Having a little trouble getting my stuff back together):banghead:
Thanks
You have to grind down a stock pole because it will hit the steering stops of the xmetal bracket. It will weaken your pole but I would do it until it breaks. That was my plan but when trying to shorten my stock pole the brackett at the end that the fiberglass rivets into broke when I was trying to break the glue apart. So, I had to break down and get the whole xmetal setup. Anyways, good luck!
Exactly what i am doing. Trying to buy time till i can afford the pole. Also, if it breaks, it's easier to convince the wife that i need one. Hard to throw away something that is working right now.
Can you still use the spring with the XMW bracket?
njfl
X-H2
Regarding waiting until the stock pole breaks...
If your stock pole is in good shape you can still get ~$75.00 on eBay for it, which is essentially a $75.00 coupon for the XMW pole. After it breaks, it isn't worth anything.
True. But then i only have $75 :frown: Not planning on waiting till it ACTUALLY breaks. Just need to buy some time.I also cut it, so i wanna see if i'm gonna like a shortened pols, and how short to go.
