XS1200 with RRP Carbon Pipe?
uk
ive rode back to back the same set up other than the rrp/pfp on a 1100 dasa. I found the rrp hit hard on the bottom but I preferred the drive of the pfp with smooth power.
I rode a xs 1200 with pfp at the weekend and found it easy to ride for setting up a wake but them crazy power when it came to performing a trick mid-top
surely fitting a rrp pipe would just make for an unpleasant ride with to much brap right of the bottom.
Philip Clemmons
Owner, P&P Performance
Richmond, Va
Can you elaperate on that Philip you a the one too know ???
Keith and Dan are both right.
Dasa setups are typically very snappy off the bottom and pull into the mid-top, but the biggest hit is off the bottom. The XS stuff is fairly tame on the bottom, but starts in the mid and pulls very hard up top.
Either setup can work for you, if the rest of the boat is setup accordingly.
There were several great running boats from both manufacturers at world finals.
