- uk
I have a mod b pipe to run on this set up .would it be worth finding a limited chamber to have this done to? Anyone gone from 1 to the other noticed much improvement ?
It's for when running an aftermarket waterbox, aftermarket waterboxes don't provide the proper backpressure, stinger mod fixes that... At least that's what I understood when talking to Xmetal
Pretty much, i was told that the loss of back pressure = loss of power....so run the stinger mod with a/m waterbox and the problem is fixed... im just running a stock waterbox, thats like $300 you can spend on say a trim... but you are giving up civic powerSpend a lot of money for more noise?
Just to clarify, the stinger mod being discussed is not a generic, make power on any motor mod. It is the mod X-Scream reccomends that be made to a limited chamber to be used specifically with an SS865.
OCD is right if your builder tells you to run a mod its probably of a reason, I'm putting in an order for some stuff this afternoon, I'll ask what it does and let you guys know what they say
I'll intently listen this time!
