Id be careful running the extreme throttle plates in the surf and jumping...I ran a set of there older style and bent the front part of the plates that over hangs the front mounts when jumping in the waves, and motor ended up rubbing on the hull...switched to Ada plates and didn't have any further issues
With that said...I did find the triple real heavy in the waves, stable yes with the added weight but it felt like a rock dropping when landing. Ended up switching back to the twin as I found it much better for wave jumping, lighter and more nimble, which is what I use it for.
Flat water or light chop and the triple really shines, and way better than a twin. Handles better and lots of cheap power on pump gas. Definitely a fun ride.
