did you hear back?Hi, I have a 64x 760 motor and am interested in a set of templates for it.
Sent you an email - let me know.
Thanks - I hadn't heard back but all all good as not in a hiurry at this point.Sorry guys, I have been busy with work and am currently out of stock on these. I am doing what I can to be ready to ship after the new year.
HelloHola
Sé que este post estuvo en espera por mucho tiempo, pero lo encontré y es súper interesante.
He descargado el YAMANUBEYAMAHAPORTINGTEMPLATE y al comprobar las medidas el ancho del puerto de escape me da 62,1 mm.
Si el diámetro del cilindro es de 81 mm, el ancho máximo sería del 70%, que es de 56,7 mm.
¿Qué ancho tiene el puerto de escape en la plantilla?
gracias
This ^ probably one of my most frequent questions I get.Are you measuring you width of the flat pattern? If so the chordal width of the port will be lower.
It depends a bit on what your bore size is but the port width is measured across the chord. These are CAD drafted and designed, I'd have to look back at my drawings but I think I am about 68% bore width at 81mm bore.Hello
I know this post has been on hold for a long time, but I found it and it's super interesting.
I have downloaded the YAMANUBEYAMAHAPORTINGTEMPLATE and when checking the measurements the width of the exhaust port gives me 62.1mm
If the diameter of the cylinder is 81mm, the maximum width would be 70%, which is 56.7 mm.
How wide is the exhaust port in the template?
Thank you
HelloIt depends a bit on what your bore size is but the port width is measured across the chord. These are CAD drafted and designed, I'd have to look back at my drawings but I think I am about 68% bore width at 81mm bore.
Thanks for helping clear this up. I originally had two templates, one for 81-83 and one for 83+ but after looking at how minor the difference was, I opted for just one to simplify things on my end.
