Correct, but the 650 timing curve isnt as good as the 62t.Itl work on a 701 but it'll have a lower Rev limit. You can mod the cdi for a raised limit though.
Good backup for testing. You will want to make yourself a jumper for the white/red stripe wire if you are using a 62t stator. The gender needs to be changed to match up. We can make you one if you dont have the oem barrels.I was just looking for a spare to take to the lake for the summer. I’ve look at the CDI mod forums but not sure I want to mess with the potting myself. May send this 650 one off to be modded.
