dirkdiggler
- WI
YAMAHA – MOTORS + Parts:
701 61x cylinders = $150
Yamaha 701 61x Motor = $449
Yamaha 701 62t Motor = $550
YAMAHA 650 Engine = $350
YAMAHA - HIGH COMPRESSION HEADS:
701 Twist Girdle head = $235
701 MRD Girdle Head = $250
701 Greater Yamaha Girdled head Complete = $215
701 ECC Girdle head with 34cc domes = $270
701 protec Girdle head = $199
701 BRAND NEW Triton Head = $135
701 RED West-Coast Head 30cc domes 170psi compression removable - $130
701 Pro-tec Rec head = $130
650 Westcoast Head = $120
650 Rogo head = $110
YAMAHA - EXHAUSTS:
Superjet Factory B-pipe = $500
Superjet Coffman sizzler Exhaust (similar to factory B-pipe) = $395
Superjet R&D Dry Pipe = $425
Superjet Factory Type 8 Dry pipe = $390
SuperJet Pro-Tec Pipe = $299
FX-1 Coffman Exhaust = $395
WaveBlaster /VXR / WR3 Riva Red Pipe = $345
Wave-Blaster / VXR / WR3 Coffman Exhaust = $265
Waveblaster / VXR / WR3 Pro-tec exhaust = $299
WAVEBLASTER 2 Pro-Tec exhaust - $270
YAMAHA - WATER BOX
1990 – 2010 superjet / FX1 Aluminum Waterbox = $150
1995 SuperJet stock waterbox - $59
YAMAHA - INTAKE MANIFOLDS and REEDS:
701 61x Dual 44mm Mikuni Carb Intake manifold = $99
701 or 760 62T DUAL 44 / 46 mm Carb INTAKE MANIFOLD = $99
650 Dual mikuni 38 intake manifold = $75
650 Dual Mikuni 44 intake manifold = $69
701 62T Boyesen Dual-Stage Power reeds with cages - $55
Stock 701 62T intake manifold with stock reeds - $30
YAMAHA - CARBURETORS:
Mikuni SBN 46mm = $175
Mikuni DUAL SBN 38 carburetors - $135
Mikuni Dual 44 Carbs - $185
Mikuni Dual 44 Taper-bored 46mm Carbs - $250
Mikuni single SBN 44 Carburetor - $89
Mikuni single SBN 38 Carburetor - $75
Yamaha stock Air Box / Flame arrestor = $45….keeps water out of motor
WaveBlaster Throttle Cable - $50
Aftermarket Flame arrestor = $45
YAMAHA - ELECTRICAL:
GP800 Stator = $89
Superjet / fx1 / waveblaster Aluminum Battery box = $55
650 or 701 or 760 Superjet/waveblaster /FX-1 Jetenetics TOTAL LOSS = $385
++NEW++ 701/650 MSD IGNITION ENHANCER = $260
701 / 650 Pro-tec CDI with Rev limiter removed = $115
YAMAHA ignition COIL with WIRES - $39
701 Electrical -BOX Complete - $150
650 E-Box complete - $140
760 Electrical Box = $150
701 / 650 CDI = $95
Yamaha 61x 701/650 STATOR with wires - $89
Yamaha 62t 701 STATOR with wires = $110
Yamaha 760 STATOR - $60
ALL Yamaha 650/701/760 STARTER - $55
GP1200 or XL1200 STARTER - $80
ALL YAMAHA STARTER BENDIX - $30
Super-jet start/stop kill switch - $75
Yamaha start/stop kill switch = $75
ALL PWC Water-proof Bilge Switch - $18
YAMAHA - STEERING POLE +:
Billet aluminum finger throttle = $45
Super-Jet or FX-1 UMI Steering Setup = $140
Superjet or FX-1 UMI Steering Plate = $50
1996 – 2011 shorter Super-Jet Pole Aluminum AC - $275
1990- 1995 Superjet Aluminum AC pole - $275
1990-1995 Superjet Stock Pole - $150
1996-2007 Superjet / FX-1 Pole SPRING - $29
1996-2007 Superjet / FX-1 aftermarket Pole SPRING = $50
2004 SUPERJET stock POLE Bracket - $50
Superjet / FX-1 aftermarket Billet Aluminum Pole Bracket = $150
Superjet / FX-1 BLOWSION Lowered Pole Bracket = $195
YAMAHA - INTAKE GRATE + RIDE-PLATE:
Superjet Jet Dynamics Ridplate = $115
SUPERJET WORX RIDE-PALTE - $69
SUPERJET Ocean-Pro Rideplate = $69
Superjet R&D rideplate = $110
Superjet / Waveblaster R&D Scoop intake grate - $99
Superjet / Waveblaster double scoop intake grate - $89
WAVEBLASTER REND RIDE-PLATE - $75
Wave-Blaster WORX Rideplate - $110
YAMAHA - MOTOR MOUNTS:
Qty 4 Nice WaveBlaster / FX-1 Motor Mounts - $50
Qty 4 Nice SUPER-JET Motor mounts - $59
YAMAHA - IMPELLER + DRIVELINE:
Superjet Pump - $190
Wave-Blaster Pump - $190
Superjet / Waveblaster impeller = $79
1990 – 1993 Superjet Intermediate Bearing housing = $69
YAMAHA - BODY PARTS:
1990 – 1995 Front Plastic Gas Cap cover = $75
Superjet Fuel Gas Tank = $89
1990 – 1995 Superjet Front Rubber Bumper = $45
1990 – 1995 SUPERJET POLE PAD = $39
1996-2008 Superjet Plastic Nose Plastic = $45
Superjet Hood Latch = $35
YAMAHA - EXHAUSTS:
YAMAHA - WATER BOX
GP800 Stator = $89
701 / 650 CDI = $95
