Yamaha Superjet Dry Pipes
Guam
I have 2 Dry Pipes for sale.
1. $250 Factory Pipe Type 4 Chamber
2. $270 Dustin Farthing One-Off custom Pipe made by Factory Pipe.
3. $270 Factory Pipe Dry Pipe Manifold
Prices include shipping and fees
Sent from my SM-G960F using Tapatalk
Idaho
Hi, I'm a new SJ owner so I don't know much. I'm interested in knowing how these pipes compare to a B pipe and also what the difference is between wet and dry pipes, and also the pros and cons of each. What would I need on top of one of these? Thanks.
Wet pipe= non water jacketed expansion chamber, typically 3 parts manifold, headpipe, chamber. Sprays water constantly thru ports in headpipe. Typically more low to mid powerband hit
Dry pipe: fully waterjacketed chamber (heavy!), chamber and manifold only, constant water spray only at stinger. Need electronic module to control water injection into manifold/chamber ports. More overall power, harder to install, more maintenance. More of a mid to top end high rpm powerband.
Guam
Water injection is not necessary, but it does improve the powerband.
I suppose it could be depending on the pipe too but my Speedwerx dry pipe is BY FAR an easier to install pipe than my B-Pipe was and quite honestly I preferred the powerband of the dry pipe over the B :)
B pipes are kind of a pain to get the chamber wedged in place, I agree. Dry pipes the alignments of everything are critical, just more of a detail oriented installer's job I would say.
sicki
Ride hard, put away wet!
anyone know if these fit in a blaster?
