Just some questions
1. Would it be ok to patch with markne-Tex and THEN gelcoat if I want the colour to be correct? (yes I know it would be hidden)
Yes.
2. What is Marine-tex - Would need to find alternative in South Africa so need to know exactly what it is.
It is a 2 part marine epoxy for doing repairs. You mix the 2 parts and then it hardens after some time.
3. If I can’t find it - What is an alternative?
4. So I would do the entire hull to get the colour back: Would I not be removing any clear coat by mistake then? Can I use a polishing machine for this? Or does it have to be straight lines by hand?
The hull is gelcoat so there is no clear coat. You are removing to top oxidized layer. If your hull isn't really bad and chalky you don't need to do the wet sanding, just the polishing and your's doesn't look that bad.
5. I suppose any hardware/auto specialist would know which medium and fine cut product to recommend - anything I should know about what might be better for marine application?
I like the Meguiar's Marine line since it has a lot more lubricants and oils for gelcoat that the automotive products don't have.
6. Medium and fine cut - Does that refer to the grit of the compound applied? Do you use a polishing wheel and apply that to it? Which type of polish wheel (Wool etc?)
Yes, I would start with Meguiar's Marine Power Cut then finish with their High Gloss Polish.
6. What is a machine glaze - Assuming the auto specialist/paint shop would know?
It is the final polish with the least grit like Meguiar's Marine High Gloss Polish.
Sorry for the million questions - Just want to be sure, so easy to destroy paintwork!
Oh and lastly - I would fill with scratches and chips with the gelcoat and apply that clear plastic film to set: Would it need to bulge a bit to not contract and become a bit hollow in the place I filled? How do you achieve that when you apply that plastic piece over it which then flattens it out?
Yes, sometimes it take 2 applications to get it where you can sand and polish it smooth. It will not be perfect but better than seeing fiberglass.
In all honesty your ski is so clean I would just wax it and go but if anything just use a polish and it should be perfect. The nice thing with a finish polish is you can even go over the stickers and it will not hurt them. Anything more aggressive an you will have to mask off all the stickers or you will burn through them.
Here’s my Blaster 2
