Yamalube
FL
def not, citgo sea and snow is not tcw3 certified.
I have always been under the impression that yamalube is very much like the penzoil synthetic blend.
crammit442
makin' legs
here
I don't believe that Yamalube(2W or 2R) is TCW-3 certified either. The Outboard Yamalube may be though.
dfw
Citgo sells the same stuff at half the price. Sea and Snow works very good as well but does not have as much corrosion protection and leaves the exhaust dry instead of greasy.
dfw
Most couches can make use of an air cooled spec oil like Sea and Snow. TCW3 is better if you are not running full throttle for long periods.
