oxnard111
Creative RE Purchasing
- so Cali, Ventura/Oxnard area
Wut?
The only thing I can think of for 8mm are the nuts on the steering cable ends.
hood latch nuts and bolts are 8mm
Wut?
costco has that tool kit every once in a while for like $35I usually grab this:
I know I could throw out about half the contents, but the plastic case makes it easy to grab at once as opposed to picking out individual tools I might need from my big tool box. The ratchets are actually decent quality, much better than the sh%t craftsman sells lately. And the whole kit is cheap enough (google says $50 picked up at Fry's, $90 at Drugstore.com but use bing.com cash back for a better deal).
This is for my local lake trips, for anything further we pack lots more electrical stuff as well as replacement parts.
Aaron
Not a maintenance item you need to take care of on the beach, though.
Who needs a 701? Ride a 650!
My long haul kit consists of...
- 181 pc. socket set with the most common metric and SAE wrenches
- GelSeal anaerobic gasket sealant (dries and cures within 20 minutes)
- Red and blue LocTite
- Additional Allen keys
- Mini ratchet meant for screw driver bits because sometimes you just can't get a screw to break free with a driver, or they're in too small of an area
- 1/4" drive ratchet with long extension, several short extensions and flex knuckle
- Typical screw driver set
- Additional wrenches from 5/16" (and metric equivalents) and up to 3/4"
- About 3 adjustable wrenches: 2 mediums and one large
- Wire stripper/crimping tool
- Side cutters
- 2 pairs of Vice Grips (regular and needle nose)
- 2 pairs of pliers, needle nose (reg. and extra long), and water pump pliers
- Pipe wrench and 2 ft. piece of pipe to be a handle extension
- A roll of wire, solder and torch, heat shrink tubing, lighter and butane
- Digital multimeter
- Di-electric grease
- Wheel bearing grease
- Wire harness for testing trailer lights or to be an extension to connectors for testing whatever
- Spare kill switch lanyard for those that might need one
- 2 hammers, mini sledge and regular
- Hacksaw blades (they work well in Vice Grips)
- Any cold weld compound like JB Cold Weld
- Epoxy putty stick
- Zip-Ties
- Butt connectors, eye connectors and battery lug connectors
- Electrical tape
- 2 sets of spare spark plugs
- Spark tester
- Stainless gear clamps
- Fogging oil
- Penetrating oil
- Impeller removal tool
- Feeler gauge set
- Long flexy magnet (not everything on a ski is stainless...IE: the acorn nuts on Kawi Heads...magnet worthy chrome)
- Cable lubricator
- Work light and 450 watt power inverter
- Air pump
- Can of tire sealer
- 4 way tire wrench and mini scissor jack
- Truck and trailer light harness connectors
- Sanding cloth
- Half moon and flat files (coarse and fine)
- Dremel Kit (works great off of the power inverter)
- Spare trailer coupler pins
I think that about wraps it up for me lol. Just a small list haha :bigok:
Think I've noticed a trend.
the salt water guys are trending more tools than the freshwater guys.
