- Alaska
Tell me if I’m crazy or not? This is what I’m thinkinking, use a PDCIS-02T for a Yamaha 760 in a 550sx reed and retain the charging capabilities. I want to try and keep it looking as stock as possible. Start by machining pickup up coil bumps into a stock flywheel (plus the stock flywheel gets lightened at the same time). Mount the 760 pickup coil in the front cover, probably sit somewhere between the flywheel and starter (will take a little welding and machining). Mount the Zeel electronics in the stock electronics box (probably have to make a spacer to make the stock box bigger). Use the 760 coil assembly and somehow mount that in the stock Ebox. Retain the stock charging coil and voltage regulator to supply power to the Zeeltronics. Thoughts, ideas, suggestions?
