Zeeltronic set up for 2 cyl. Yamaha
Just one of the pictured f/w included. Flywheels are either lightened charging (heavy!), or t/l with welded ring gear from member speedy sprocket. If you look at the pics on a large screen- you might notice new cables and rebuilt coil with 8.5 MSD carbon core wires- they don't fracture from vibration. Electric box and f/w cover are very low hours (paint is original). Bat. cables are marine grade. $980 shipped lower 48- If we're friends or relatives on PP- otherwise add pp fee. Detailed pics of f/w's can be had on request. This is just one of 3 sets available,. Note, pictured gaskets, spring and 2 washers for the Bendix, as well as rubber plug (discontinued by Yam) for crank case opening are included. Also included is a extension (ribbon) cable, if you later should wish to change the timing curve.
Optional is a (USB) programmer = + $55. The 2 items shown in the last pic are not included. The modified handle bar switch, also the CPI switch with long cable are just shown as a suggestion.
One of 3 other set ups available, - however someone bought the pictured oem coil, so now all my units (relax: there wont any more) will have the customized coils shown and described in post 1.
