- Washington
Hi, its my first time installing a zeeltronic and was hoping to get a little help and feedback with the wiring. I attached a picture of my wiring
I have supplied a fused power wire to the zeel but am not sure if all the wiring is correct, I have 3 leads that i don't see a connection for.
There is a grey wire off the Zeel with no connection that does not route through the zeel harness plug. Is this the switching wire between programs? Does it just need to connect to ground? Online Zeel shows in their wiring diagram that the grey wire is the signal counter wire? Is this old info? Doesn't the counter go through the prebuilt harness?
I also have a pink wire that splices for a male and female connection, both of these ends are not connected. Is this normal with the install? Can I just plug these into them selves just to close the wire ends?
There is a orange wire off the harness that runs to the flywheel area that is not connected? Is this correct I don't see any place for the connection
Any help would be greatly appreciated, thanks
