Zeeltronics on a xs1200 motor
Curious to see if anyone has been able to put a zeeltronics set up on an xscream 1200cc motors? I have a full zeeltronics set up sitting here off my 1100 and I was hoping to keep it as a back up for my 1200 instead of selling it
Jcary85
Glenmoore pa
You just need a gp800 front cover. Cut the mounts, unnecessary bracing and bottom bolt hole off and you are good to go. It plugs right into the zeel. Same static angle even. It’s an oring cover from the factory by the way. 760 or 800 flywheels work. Obviously your choice on lightening, magnet removal, etc. assuming you setup an identical curve to your MSD you should have no performance change.
