Freestyle Zeskis XFS
Big Kahuna
Administrator
Tuscaloosa, AL
Chris pulled his motor last night, I went out and pulled the rails. 2 holes on the exhaust side are stripped out, think we can get longer bolts to grab farther down Those bolts that come with them are very short.
waterfreak
I had a vision!
s florida
I think that whole adjustable bracket is a bunch of crap. When would you ever want to move the motor forward when the further back is the best position possible for freestyle.
Here's what I noticed when I put mine together. You have to remove the bracket to put the motor mounts on. Yes, the bolts are way too short and they also used lock tight on them even though they have to be removed for installation ...WTF!
anyway, great build Cris ! can't wait to try it out
Big Kahuna
Administrator
Tuscaloosa, AL
You do not have to remove the bracket to install the mounts, actually you cannot unless you only bolt one side of the mounts. We installed the mounts with the rail bolted down. Chris (Buddy) is not building a one trick pony XFS. He is running the supplied spacers on the crank side and shaft side. Tricky felt the motor was too far back on his first build with his XFS.
yeeeeheeeeew the 900 is in! I even got some special black novis instead of silver. This thing looks so bit-chin. Tomorrow I will start and run it, I still have some more little things I want to do to make it mine but here's a quick pick. Finished it tonight at 1230!
