You might need to decrease the pop-off slightly if you find out it is hesitating (lean) when applying throttle...this is common when swapping the stock air intake (with restrictive screens) to aftermarket flame arrestors. It makes the intake more free flowing, which decreases the pressure in the intake manifold, which affects the ideal pop-off setting. Removing the choke butterflys kind of does the same thing in that it makes the intake more free flowing, but to a lesser extent.
Try it like it is, but keep that in mind just in case...
