Super Jet Will taking the choke butterflys out of the stock 38's require a rejet?
Not recommended to do this per Chucky at XS, do a search on it....fyi
Also, not worth the very little gain was the consensus of others on here as I recall...
MikeyB
H2O-Addict®
Michigan
I want to say it will only alter the popoff slightly? Not too sure, have to wait for someone else to chime in.
You might need to decrease the pop-off slightly if you find out it is hesitating (lean) when applying throttle...this is common when swapping the stock air intake (with restrictive screens) to aftermarket flame arrestors. It makes the intake more free flowing, which decreases the pressure in the intake manifold, which affects the ideal pop-off setting. Removing the choke butterflys kind of does the same thing in that it makes the intake more free flowing, but to a lesser extent.
Try it like it is, but keep that in mind just in case...
orlando
yes stock pop off is like 55 with chokes and stock FA. if you are running no chokes and stock FA try 30 psi. if you are running no chokes and aftermarket FA try 20-25 psi and likely can rejet 2-5 up
West Oz
it allready has twin f/a's I just want to remove the butterflys that arnt even connected when I upgrade to vforce reeds at the same time, There not doing anything anyway
Poizen
Mical
South Africa
take them out
richen low and high speed screws 1/8th turn and you should be on the money
don't listen to the kak they are hard to tune blah bla blah its all bullkak
enjoy
