MattSmith
Wanna ride tommorrow am?
Just picked up a 95 Blaster that's all stock for 8 hundred bucks that needs some love. I want to set it up for surf and maybe eventually have Carter come and do the rocker for me.
The guy gave me a Coffman pipe that looks like it has been welded not sure why but how does the Coffman compare to the factory b pipe? same power? little less?
If I were to use the coffmin pipe what prop or pitch would be optimal four 170 psi. It is stock now with a beat up blade. Same about as a super jet?
I am 6'4" so I need high bars what's the best way to get the bars really Highup there. Stock now.
Here's a pic of the pipe not sure what's going on with the weld.
Would be better just to go by a factory b pipe? Can you use a super jet pipe or do you have to get the Blaster type that turns.
