SB Products Billet SuperJet engine case
wsuwrhr
Purveyor of the Biggest Brapp
After a year of development, 300-400 hours of design and machine time, I was finally able to finish the first billet Superjet case that I know of.
I started out with a 16MM crank, but these cases could be used with any stock stroke or stroker SuperJet crank.
I tried to remain true to the look and feel of the SJ case and to keep them within 5 lbs of the factory case.
Uses all factory bolt-ons including, cylinder, intake, ignition, mag and mount pattern.
As some of you guys know, I manage DASA's machine shop and I run my own shop as well. So it should come as no surprise, I built the transfer base to match the DASA/Lamey cylinder, but I could make it to match any cylinder.
What do you guys think?
wsuwrhr
picture.php
Right out of the machine in this shot, still have to drill the starter mount holes.
2lick
Brap!!!
Limerick, PA
I don't have anything valuable to say... other than WOW those are nice!!! I'm sure this will help some guys go to the next steps... and thanks for putting in the time!
waxhead
wannabe backflipper
gold coast
i know how much work would be in the drawing alone
very impressive
i just had a moment when i saw those
ok how much
waxhead
wannabe backflipper
gold coast
can i offer a sugestion
since your taking a plunge from the front
put a oring groove in front so you dont need a front cover gasket
wsuwrhr
I just want to add.....
These pictures are from mid-October, at this time the cases are nearly complete. I have been swamped trying to finish the details of the case and lightening them up where it is safe to do so.
I have a total of three cases, I am trying to decide which builders will get the first three. I am going to start the first production run at 10 cases, unless I get a few people ready to step up.
I can imagine the torque this thing will make will be significant, pumps and props will need to jump up pretty big to keep it pulled down enough. The bottom hit like a train and the top end will just keep pulling.
Brian
waxhead
wannabe backflipper
gold coast
oh hell yes 1200cc of pure power
it will be sensational
A dry pipe and a good set of carbs
Will make a nice race engine as well
waxhead
wannabe backflipper
gold coast
yeah hard anodizing them black would be awesome
and they would always look good as well as they wouldnt corrode
i may look at a set when i turn my 2008 superjet into a gp boat
QJS
X-
GONE
I take my hat off to you Brian I know exactly how much work is involved, I keep looking at cases thinking I should have a go but it takes about 30 seconds to talk myself out of it. Nice work.
Chris.
