SUPERTUNE
Race Gas Rules
- Clearwater Fl.
I suggested Race gas and MSD TL to anyone that going to TRY this pipe for the first time, This is a safety margin so you don't get discouraged running this pipe for the first time.I did know that you had to run 112 octane fuel but I didnt know about needing a msd TL system. This would be a total custom setup but I found a guy that would be willing to custom make a manifold for me. You would probely laugh if you herd what motor I am trying to build.
If you miss the setup just a little,you'll burn the tops of the piston in about 10-15 minutes.
jetski9010 didn't even say what engine setup he even has!
So I gave him SOLID advice to make serious horsepower using this pipe...
btw, I do NOT run race gas -that. Bad enough I have $20k into this 'ski, I don't want it to cost a fortune in gas just to ride the damn thing. I am just an average Joe like most everyone here. I ride 3 to 4 days a week and have a mortgage payment to!
I am running 94 Octane, very few WOT runs and my timing/compression is setup accordingly by the man Supertune/Chuck himself
When I have TOTAL control of the entire engine build, I can setup these pipes to run pump *93 oct fuel with freestyle/freeride in mind.
These PFP pipe were developed for BIG POWER and you do not make big reliable power using stock Yamaha ignition (analog) even with a TBM aluminum flywheel and a MSD Enhancer cdi.
Will work just not big power off the bottom to overcome a 'B' pipe system. Most guy's that rode any of our (Patrick Bogart's) 1000's when we ran our water injected 'B' pipe setups couldn't believe it.
